How do I set a select when a checkbox is checked?
For some content, I have a task database, I have a row called “Done” which contains a checkbox that outputs true when clicked. I would like to set set a status column on the same row to “Done” when the box is checked. I’m sure there is a way to do it but I’m new to Coda formulas so any help would be great! Cheers!
Hi Wayne,
There are two ways off the cuff that I can think of to d it.
The first is to create an automation that will trigger when the checkbox is ticked. (Row changed).
This is not instantaneous.
The second is to have a button to tick, rather than the checkbox. If you need both the checkbox column and the text column, I have set it up so that you have both.
Examples in this page:
Hope this helps.
Piet
