it doesn’t appear in table’s options…
Ctl-z.
Will undo the most recent change, regardless of what it is.
Our you can restore from a previous version.
It all depends on how intricate the restore is that you want to do.
Thank you. what do you mean by “Our you can restore from a previous version?”
Top left you will see the three dot menu, click on that, then click on Open doc history. That will give you a list of older versions that you can use. You can either restore the old version, and discard the current version. Or you could just copy specific date from the old version to restore - pages, rows, tables, etc.
Oh thank you very much! you can’t undo from the menu like in notion? we only have the shortcut?
