I need to show how many times each item from a list repeats itself. Something like this:
And below the embedded doc of the example above:
The solution probably involves the use of FormulaMap, but I can’t get it right… Does someone have a clue?
hi @Carlos_Roriz_Amplus_Construtora
something like this:
and for the part II:
thisTable.Filter(Attribute.Contains(thisRow.Attribute)).Count()
I could not open the doc, so you see a screenshot from me.
cheers, best, christiaan
Thanks for the reply, but I think I wasn’t clear enough. What I need is the column highlighted in yellow (I created it by typing it, but I wanted to create it using a formula), that shows, for each day, a list of unique attributes associated with each person listed in the name column with its respective number of repetitions. Something like:
I fixed the doc sharing settings. Now it should be possible to be played with in the embed.
This was a fun puzzle. You have to remove bulletedlist() on your [Attribute] and [Unique List] columns so they can be parsed as lists/arrays. Here’s the solution @Carlos_Roriz_Amplus_Construtora :
thisRow.[Unique List].FormulaMap(
WithName(CurrentValue,uniqueLetter ,
WithName(thisRow.Attribute.Filter(CurrentValue=uniqueLetter).count(),letterCount,
concat(uniqueLetter," (x",letterCount,")")
).BulletedList()
Thanks a lot, @Johg_Ananda !!! I’m still trying to wrap my head around this nested WithName(), but it works nicely… LOL
THANK YOU !!!
OK here’s how to think about it. You’re looking for the count of each letter in the [Unique List] column, or the count of each unique letter, uniqueLetter.
For each unique letter, we want to filter the column [Attribute] and count the number of times the unique letter appears, letterCount.
So FormulaMap() says for each uniqueLetter in [Unique List] lets do the following:
Take the [Attribute] column, and check each value in it to see if it matches the uniqueLetter. Count the matches. I do that with:
WithNames() allows us to break up each step and convert the formulas to variables that are easier for our minds to deal with.
I use uniqueLetter and letterCount because they represent the pieces we need to combine to the solution.
It also overcomes a technical problem when we are looping in a loop. Coda uses currentvalue as your marker in the loop, but when you go into a second loop you get a collision. WithName() avoids this.
Representing the formulas as variables also makes downstream code cleaner and easier to understand. The formula:
is beautiful in that it works technically and reads literally.
Let me know if there’s anything else I can clear up.
very well explained @Johg_Ananda !
You didn’t need to go through all the trouble to also explain your formula, but I really appreciate that! It’s clear now. Thank you!
