How to count same objects in list
Hello its my first question here, i would like to know how to count same object in a list.
I have to build a real-time update of stock from planning rentable bike.
I have a list of rentable bike between 2 dates like (to not consider product’s name):
LIST BETWEEN 2 dates:
[coco,coco,nageur,dada,coco,chapeau,chapeau]
i would return this :
-coco: 3
-dada: 1
-nageur: 1
-chapeau: 2
it been > 1 week i tried to solve that:
i filter list of product between 2 dates with .Unique(),
then i run on each different product with formulamap() and countif(), the sum on same product in list (but without .Unique() )
And i hope to find count of each product find in list.
But i find: 1 , 1
Location
  .Filter(
    sequence_periode.Contains(sequence_days)
  .rowid_product
  .Listcombine()
  .Unique()
  .FormulaMap(
    CountIf(
      CurrentValue,
      CurrentValue
        .contains(
          Location
            .Filter(
            .rowid_product
            .Listcombine()
may i’m not clear,…
Hey, after some re-re-read on community forum, i fund solution:
i use withname ton nested value and loop trick.
sequence(
  1,
  Location
    .Filter(
    .Produits
    .Listcombine()
    .Unique()
    .count()
  .formulamap(
    WithName(
      CurrentValue,
      seq,
      Location
        .Filter(
        .Produits
        .Listcombine()
        .countif(
          CurrentValue
            .Contains(
              Location
                .Filter(
                .Produits
                .Listcombine()
                .nth(
                  seq
:wave: Hey there!
Im unclear exactly what you are looking for, but from your initial post, you may be able to find a simpler solution to your problem
Here is an example doc with some example formulas - Hopefully that helps you out!
Thx you ton help, it help me that in pqrt what i would like, keep help eqch other, hqve nice day
