How to format dates inside a formula syntax?
Hi Codaers,
I wanted to pull the first date (older one) on a table to use it as a document formula:
I write “You have done X since and use =TableName.DateColumnName.min()“ and it works perfectly giving me the smaller date (oldest).
What i need is formatting the formula and extracting just the Month name and the year to have something like this: “ You have done X since MonthName YearName”
Any clues?
Giacomo
Use MonthName() and Year().
@Stefan_Singer thank you, that’s not what I was exactly asking for as I needed a nested formula. I have solved in this way:
A) Named a formula with tablename.datacolumn.min in the bottom of the doc
B) applied the syntax referencing to the formula name.
I’m not sure I follow. What I meant was something like:
CONCAT("You have done X since ",
  MonthName(TableName.DateColumnName.Min()),
  Year(TableName.DateColumnName.Min())
Which gives exactly what you stated in your question.
Screenshot from one of my tables:>
Perfect, I was missing that you always have to specific the table and the related data point for every formula argument! Now it’s working perfectly.
Thank you so much, I solved!
Giacomo
