I created a sync page that contains a table from another document. I set the permission to “Everyone in the doc”, and it became read-only.
One thing I noticed is that the layout when opening a row in the original document, and the layout applied in the sync page are different. The sync page seems to be using the default layout, while the original page is using the layout I set myself.
Is this currently a known limitation? Is there a way I can keep the layout from the original document?
