How to make a URL scheme in Coda
I want to add a given URL to the Read for Later app “Later
This is the URL scheme: later://add?url=
The URL in the example is “https://hq.getmatter.com/
I have created a column in a coda table using the concatenate() formula which contains the full url: “later://add?url=https://hq.getmatter.com/”. I have created another column with a buttom to open the hyperlink. Anyhow, I always get the error message: “Attempting to open an unsafe url - later://add?url=https://hq.getmatter.com/”.
Is there a simple solution for this issue?
Hi @juergenheise,
I think there is no simple solution for this, unfortunately.
There are other topics about this issue:
Best regards
Jannis
Running into the same problem.
