MacOS allows a browser to treat local app URL schemes as links.
For example:
zotero://select/library/items/6SPU6X11
is a valid URL which opens the Zotero app
If I create such a URL on a coda page however - either as a rendered HTML Href or in a “Link” column - it is not recognized.
Is there any trick in either Coda or MacOS so these links are recognized when clicked?
Have you tried using the Hyperlink formula?
Thank you for the suggestion
The Hyperlink formula results in the same thing as a rendered HTML Href. I get a link that looks like it “should” work given what it references- but the browser does not respond.
I am not sure if this is an issue with Zotero (my app), an issue with Coda, an issue with my browser, or an issue with MacOS.
