If Attachement names are wider than the column they flicker
2021-05-21_19-08-05 (1)
(Its faster in reallife, the gif made it slower)
I noticed this as well, and I found that if you turn on the columns ‘Wrap Text’ setting, it no longer flickers.
And because they are file names I guess, turning on wrap doesn’t actually make the cell bigger or break the table formatting in any way
ok, thanks for the workaround, will try that.
Yes Turning on ‘wrap text’ works around the problem. However still a small bug :bug: that needs to be fixed imho.
