I am trying to return a 0 if a whole operation is blank, its long enough to copy and paste it again in the false value, any alternatives?
You can use WithName() to give a name to a bunch of formula code.
Somecomplicatedstuff().blabla.etc().WithName(
MyStuff,
If(
MyStuff.isBlank(),
0,
MyStuff
This takes your complicated code, gives it the name “MyStuff”, and then you can use MyStuff to reference that result in multiple places.
thanks! I managed to do th formula
