Issues with Currency Converter pack
As of a few hours ago, the Currency Converter pack is not working for me. It errors out with “Your credentials to Currency Converter are not working”. I already tried testing the pack in a fresh doc, and while it works at first, the error still shows up like 2 minutes later
Sometimes it shows a different error: “Failed to fetch data from Currency Converter”
I’m also seeing similar problems today.
Is there any update from Coda as to what is going on?
I just sent a ticket to support@coda.io . Now when I try to use the formulas it says “Couldnt fetch data from Currency Converter: too many requests sent”
They just answered! Quite fast I might add. They told me they are already looking into it and that a fix should be on the way by Wednesday
The issue seems to have been fixed today
