Moving from Coda to Superhuman
Hi,
Just wondering if there’s been any updates on whether it’s possible to move from a coda subscription to a superhuman subscription or is that not currently supported?
Hey @Mick_Hollins!
At this time, there isn’t a way to directly merge an existing Coda workspace into a new Superhuman suite workspace. However, you can purchase the suite, migrate your documents from your old workspace to the new one, and then cancel your previous Coda subscription. If you have questions about managing any remaining time or credit on your current subscription during the transition, I’d recommend reaching out to our support team at support@coda.io. They can work with you on your specific situation.
