Moving rows up and down with buttons
Hi, is it possible to move a row up or down with either an up button or a down button?
Tony
hi @Tony_Reid1 ,
I wonder about the use case, would you mind updating on this?
dragging the row via a button to another position seems not possible to me, but change the position in a sorting you can. Use a kind of Index type thisTable.Find(thisRow) and a second column in which you modify the value via + 1 or - 1 using ModifyRows(). The relative position can result in a different sorting.
moving through a table with a back & next button has been explain by @Max_OBrien and you find his contribution here:
cheers, Christiaan
Thanks for your reply @Christiaan_Huizer.
The reason for doing this is two fold:
  1. so I can adjust the order when the table is sorted;
  2. so I can adjust the order when the table is embedded in the layout of a detail view.
Lot’s to digest in your post. Thanks to you and @Max_OBrien.
Tony
Hi Tony,
What you are looking for i snot going to be possible. Coda’s sort does not work like Excel sort, one and done.
The Coda sort is dynamic (?) - With that I mean every time that a change is made to a table, the sort is reperformed. If you move a row, Coda is going to sort it right back into its place. Which means that you would need something like Max proposed - a method to change the sort sequence.
Regards
Piet
