Separate manual sort order per table view?
By default, of course, manual sorting mimics the same order in all views of a table. But I have a table with two views where each view needs its own manual sort order, sorted by drag and drop. Is there any way to implement this?
Hey there! Welcome to the community.
And sorry, no. I don’t believe there is a way to do this ;( Many things are possible in Coda, but not this.
Would love someone to come prove us wrong though!
That is my understanding as well.
Drag and drop changes the Table Order - there is no View Order. Only Table Order, Sort Order and Creation Order.
P
Not by drag and drop, but you can accomplish something similar using buttons. The setup is not complex but not trivial either. Once it’s implemented it’s transparent to the user though.
Edit: Issue with deselection solved
I just ironed out the little issues the doc had, now it should work as expected with only a small delay.
