I am writing a manual and inserting numbers in front of the order, for example, 1. Open, 2. Select, 3. etc…
However, if a picture is inserted between the numbers, the number under the picture reverts back to 1. What is the solution?
Hi @anon47278160,
Use Shift + Enter to go down a line without creating a new number.
E.g.
The image above becomes part of number 2 and so doesn’t break the sequence.
All the best
Dale
