Recently I had to limit image sizes for a doc I was building, in order to reduce it’s file size, and I remembered how Paul Danyliuk said that Coda uses ImgIx to deliver its images.
So I’ve built this pack to perform that task, with a lot of options for you to play with (probably more options than you’ll ever need
- Set a maximum width or height, or define both dimensions.
- Apply fill effects (blur, solid color, gradient)
- Apply corner effects
- Set a specific file output format
And even more granular controls.
Get the pack here and see the sample doc to play with the controls.
