Search long tables
I have long tables. I’d like to use Ctrl+F native search box to find rows (like in Google Sheets).
However, right now it doesn’t work. I assume that Coda removes the HTML elements to free up memory. But that breaks native search.
Is there a workaround for this?
Or at least an option in the profile to not remove elements? (I can switch it on my machine with good performance & lots of RAM)
A textbox on the canvas and then filter the table on the contents of the textbox is really the way to go in Coda - it works very well.
A sample is provided in my sample doc - copy it to your space to check the formulas: samples and resources by Joost
