Does anyone know how to get GA4 and coda to be streaming? Is Coda not updated to the GA4 new requirements and thus right now it’s not even possible? I have my Measurement ID available and it’s in the Coda publishing section. Since it’s a simple copy/paste I’m not sure where it’s going wrong except that Coda doesn’t have the capabilities of processing GA4 data?
Anyone else able to set up this integration?
I have had successfully received data in GA4 from my published Coda pages until recently.
Now it doesn’t work. “No data is available”.
I haven’t changed anything on the Coda.io side
So weird. I set it up about 3 weeks ago, is that about the same time you found it to drop off?
Feels like a coda <> GA4 problem? It’s basically a 1 line set up?
I’ve reached out to Coda support, and they told me that there was a problem, seemingly on GA4 side (
), and suggested me to delete and add back the property in GA4.
The same day I’d sent them the request, data started flowing again.
