Is there a way to share a link to a single document - without the viewer seeing all of the sub-documents in the side menu?
Dear @Steven_Kryger ,
It’s not clear in what context you are questioning this, but:
It is possible to hide some of the pages in your document, so they won’t catch the eye.
You can do that as in the screenshot below:
Just be aware that only makers will be able to un-hide these pages, and that when un-hidden everybody will see them again.
So when it’s only to filter out the “noise” it’s a good solution and something in almost 100% of my documents I am doing this.
Thank you, this helps.
I’d like to share links to individual docs with clients, but for them not to be able to see all of the sub-pages. However, hiding the docs makes it difficult for me to edit - I then need to ‘unhide’ when I want to use the other docs.
Is there a better way for me to go about this?
If it’s only to share certain content from one or more pages of your doc, depending on the use case, you could consider to copy them to a new doc and share this doc with your customer.
Of course it’s important to keep the naming convention of your docs in a self explanatory way, just for yourself to be able to identify each doc.
