Stuck with Formula on PT Score Tracker
I am attempting to create a physical training test score tracker that pulls the score from different tables (Male PRT or Female PRT) based on gender and age. I’ve attached a screen shot for reference with my formula which sort of returns the correct score for Row 1, but incorrect for Row 2 based on age provided.
Score%20Formula
@Joe_Rivas
Can you share a screenshot of the table [Male PRT All]?
Thanks for taking a look. I’ll have to also do formula(s) for each age group and gender
@Joe_Rivas
I’m headed out the door, so I’ll just leave this here and hope it keeps you moving forward. I’ll check back later.
This logic should work (but I did it in a rush so you may have to fiddle with it).
IF(age >= 18 AND age < 25 AND Gender = "Male",Lookup([Male PRT All],[Sit-ups 20-24],[sit-ups]).[Percentile],"different demographic")
Once you get this logic expression working, then you’ll likely want to build it out into a larger SwitchIf() statement to allow for different genders and age groups. :point_down:
Thanks, I’ll work with it soon as well!
