How to sort a table in Coda using a button or a select without opening it?
Hello everyone,
I’m working with a table in Coda and I’d like to sort it automatically using a button or a select, without having to open the table view and apply the sort manually. Does anyone know how to achieve this? Is there a way to use a button or a select to change a table’s sorting externally?
I would really appreciate any suggestions, examples, or tips. Thanks in advance! :folded_hands:
Hi Carlos,
An option would be :
  • to create a Select control with the name of the columns you want to sort according to
  • to create a helper column to take the value of the column you selected on the control
  • to sort the table according to that helper column
In that way, every time you change the selected column, the table would be reordered.
THANK YOU SO MUCH !!! You have no idea how much you’ve helped me. Thank you so much, really.
