Custom/consistent branding in AI Views
Looking to get consistent UI and branding in your AI views but you’re not a graphic designer? Well so was I!
Our team is heavy users of Claude, and we use their design systems to build artifacts all the time, and it works wonderfully.
I’ve always wanted something similar like that for AI views, so our team can build consistent, branded AI views on any table in any doc and we found a great way to do just that
We launched a quick YouTube video to show you how, as well as some other tips and tricks and gotchas about AI views as you’re building them generally.
tldr; create a page in your document called "Brand Guidelines" and tell the builder (before or after you build) to reference that page and follow all guidelines there when building the app. See screenshot below for our guidelines as an example. The video also has a resource that helps you, as a non-designer, develop your own brand-guidelines to use with AI Views
Would love to know if anyone else has other ways they’ve been approaching consistent branding across AI views to get the aesthetic you’re after.
Heres an example of our design system (just an example, its much longer) but guides the AI really really well.
Scott Weir, SimplaDocs
Great video Scott.
I have a brand guideline skill in Claude that it always refer to when building artifacts within a certain project.
I’ll try your implementation as well :smiling_face:.
It would be really cool if AI inside SH could refer other docs in the workspace, in order to create and always refer to a centralized brand guidelines doc (maybe with Databases will be possible?)
Would you prefer to hold your brand guidelines in a document and have to point each AI view at it, or have a more native product feature within AI views that allows you to pick certain brand systems?
I feel like I would rather have the latter but love holding it on a page for now
I think a doc would offer more space and ways to eventually grow your brand guidelines, especially if it includes not only text but also images and external files
That “Brand Guidelines” page trick is super smart for keeping everything looking clean without needing a whole design team. Setting up a dedicated reference document saves so much time compared to trying to prompt-engineer the styling from scratch every single time. Explore the various gaming options on our website and claim your welcome offer.
100%
We used Claude to set up the brand guidelines in design, then distilled them in coda
Then made that design page a shared workspace template that anyone can /command into their doc.
This is the way.
