AI views opens today, October 20, 2026, to everyone* in beta. Mark your calendars to join Justin Hales and Jeremy Olson for our live webinar on November 5, 2026, for a deeper dive into this exciting release.
AI views is built atop one of the most beloved features of SuperDocs, expanding what’s possible with structured data.
With AI views, describe the experience you need, and AI builds an interactive view right on top of your live Superhuman Docs table. It stays in sync with your data, and you share it like a doc. You don’t need to code.
And with that, we’re beyond excited to share the news that… AI views opens for everyone* in beta today!
If you have been part of other Superhuman open betas, like our MCP open beta, this one will work a bit differently. There are no forms to fill out or any additional vetting processes to follow; you can start using AI views right away:
Creating AI views: Paid Doc Maker licenses will be able to create unlimited AI views. Everyone else can create one free AI view to try it out.
Using AI views: Everyone can use an unlimited number of AI views.
*AI views will not be enabled for workspaces that have turned off AI or use single-tenant deployments. Building AI views generally requires a paid Maker license. During the public beta, users without a Maker license can try one AI view per workspace. Everyone can use shared AI views at no extra cost.
I want to add a special thanks to this wonderful community! Many of you were early testers of AI views, and your feedback helped us reach this milestone.
If you’d like to join in on the launch conversation (and see some amazing examples of AI views), here are the announcements on X and LinkedIn. We’d love for you to share what you’ve been building!
This is an excellent update! I’m already finding interesting new ways to show the data, but I have also found two issues:
Opening related rows (e.g. open a task row from a project view) is clunky and doesn’t work as nicely as OpenRow(), and I had to have 6 iterations with the agent just to get it working relatively reasonably.
Creating rows fails to set initial values for select list columns where options are generated by a formula (e.g. ListCombine(Table A, Table B)) which is a pretty common scenario for us.
So hyped that AI Views are getting ready for the spotlight. It really can be a killer feature.
There are plenty of bugs at the moment, but none as critical as being unable to detach an AI view from a tab in another view — doing so just loses the app altogether (thank god undo still works)
“Copy AI View” to another location doesn’t work either — somehow it fails to locate existing files to duplicate the view. I’m going to try a workaround of creating a new AI view and giving it all the generated files directly. I was unlucky to set this AI View on a base table to just play around and test, and progress quite far so that now I don’t want to lose all the work
UPD: Copy-pasting the content of all the generated files worked, although the new view somehow caught some issues with the code I copied It’s a workaround alright, but ideally we makers have greater control over them.
How’s this feature not being discussed more? This is literally a game changer. Its so much fun to use and opens infinite possibilities that I literally forget to drink and make breakes playing with it! I’m obsessed and can’t wait to see AI Views to mature. I was never so excited for software before.
Major question:
Will it be possible to create PDFs or downloads in general using AI Views?
totally share your sentiments re: infinite possibilities!! what an amazing feature led by @Jeremy_Olson@Justin_Hales1 !
Creating PDFs is possible through the print dialog, but CSV download (or any download of files) is currently prohibited due to security.
with regards to more discussion…
there’s a slack channel for the ai views beta open (i believe anyone is welcome to join. Please ask @Ruggy-Joesten )… we geek out more about it there
and if you’re not already aware…there’s an event this week for it
I love this new feature. It worries me a little that it seems to create columns in the table, though. Could that be a setting? Or could the tool when creating an AI view ask for human input on this?
I have a concern that’s blocking me from trying this. Is the use of the AI secure? That is, how do I know that when I use the AI to create a view, that I’m not leaking my data back into the training of the AI? I’m concerned both about the values themselves, as well as the structure of my data (my tables, their columns, …). Thanks in advance!
Hi Scott. Appreciate you answering! I may be totally misunderstanding. I do appreciate that the normal Coda table or AI view (app) are always in sync. But it seems like the AI View starts making columns in ways that are inefficient; for example, I had a simple “Priority” column (for example, “In Progress” “On Hold” “Stalled”) with the values for that table stored in a separate table. The AI View – instead of honoring the original column settings – which stored things like where the select list is stored, the order of the items, etc.) anyway the AI view started creating columns to re-create the select list.
Once or twice this is OK. But as the AI View creates columns (with its own naming), how does one document the use of the columns? The AI View creation doesn’t leave any documentation in its wake.
Maybe I shouldn’t stress about it but in the old days when using SQL to create databases, I’d be very careful about documenting each column and I suppose it just startles me when columns are created without the possibility of redirecting the AI View to columns or logic I might already have in place?
Again, I’m probably just thinking about this all wrong, but I appreciate learning!
No, those are great observations, and I’m sure it’s just some fine-tuning that the product team needs to do behind the scenes to ensure that it continues to follow best practices in terms of Coda table and column creation (which is unique to other databases). Have you tried having the agent that creates the AI views use column-level descriptions to document what the columns are for?
That’s a great idea. Are you suggesting just adding a line to my prompt like “If you create any columns, please document what the column is for in the column description” ?
There are two limitations with AI views that block some applications: a) it doesn’t run the functions that buttons and automations do in tables and docs. b) AI views don’t control the related tables as modals
There is barely a table which doesn’t have both. Hopefully these will be resolved soon. Then the AI views would be quite a good UI and UX layer on top of all existing documents (together with some small fixes). Nevertheless, it’s one of the most exciting upgrades and I quite enjoy it. Keep up the good work!
Good point, thanks for the feedback @Christopher_Kirill_Sokolov! Working on giving the AI view agent the ability to update column descriptions so it can do a better job of this.
